sdhaber
May 27, 2020Follower
Add Ethernet Access Point to PowerLINE 1000 Setup
Which unit should I purchase to add an Ethernet access point to my existing PowerLINE 1000 setup? I don't need a wireless access point, just Ethernet.
1 Reply
you didn't put your model number.
If you're only needing one though, netgear only sells them as kits.
What you can do though is look at the model number you have, look up its product data sheet (netgear.com/support/ type in model number).
It'll show what powerline standard it uses. Any device that uses that standard should be compatible. Even from another manufacturer. And others sell individual devices.
