jwc1972
May 31, 2011Aspirant
Adding a Second wireless access Point to a Network
Hello We have an WN802t-200 connected to our switch Wireless name Upstairs Broadcast ssid yes channel - Auto MCS index Best Channel Width 20Mhz Guard Interal Auto Output Power Full Wit...
fordem
Sep 12, 2011Mentor
The DHCP pool, or more correctly, the DHCP lease pool, is the pool of addresses that the DHCP server can offer an address from. Static ip addresses, if used, should not be within the DHCP pool since this creates a situation where the DHCP server can offer that address to a device, and you would then have two devices with same ip address, or an ip conflict, which will cause both devices to stop communicating.
