Skipple
Aug 02, 2020Follower
Adding internet to garage
I want to add internet access to my garage that is approx 100 feet away ive tried adding an older router hard wired to this one but just couldn't get it to work. what would you guys suggest? Get ...
Aug 03, 2020Guru - Experienced User
You tried to hardwire in an older router?
which one?
100ft shouldn't be an issue if you've got an ethernet cable ran that distance and wired correctly.
You can run a decent cat 5e cable 300ft. what ethernet cable did you use? have you checked the ends on it?
What issues did you have with the older router?
