RingoDivo
Dec 01, 2020Aspirant
Adding mesh satelights to an existing system
I just purchaed this mesh system that came with one router and 2 satelight extenders. How many additional satelight extenders can I add to this system? Also. I was trying to compare the similar Orbi m...
Dec 01, 2020Guru - Experienced User
Which system did you buy and what system are you comparing to?
I'd generally point to this KB article https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
but the problem is the base models can't support the same. So its tough to tell without more details.
RingoDivo
...and thank you for the link!
