JW_05's avatar
JW_05
Follower
Sep 16, 2020
Adding mesh to Nighthawk X6 AC3200 (R8000)?
I bought the Mesh wifi 6 system but can't figure out if I need something different to create a mesh network with my curren router?
  • plemans's avatar
    wifi mesh 6 system could be many different systems.
    which did you buy?
  • Cant find details on this.. i want to add mesh to my network.. the current router works great in most places.. but looking to add mesh +ethernet to media areas like in my living room where the devices could use a boost of bandwidth for streaming services.  I like the nighthawk satelites they provide an ethernet for devices that arent wifi enabled or dont support faster wifi technology.
    Can I "mesh" satelite boxes directly with my ac3000 or do i have to use the router?... I know i can just plug the "internet" port into my routers network but that sort of defeats the purpose doesnt it?.. i already have fantastic speed on my second floor... i'm just looking to improve my other floors..
    any input much appreciated.
    • 2A4Life's avatar
      2A4Life
      I can say that I did buy the mesh system for the same reason as you. Was not sure if it would work out but it did thus far. I connected the mesh router to my R8000 and then went through the normal set up and it works good so far. Only day so I am sure there may be a few hiccups. None the less it is solid right now, I have two networks and a password for each with the satellites around the house to help my outdoor cameras.
      I did notice that in the app when I switch between the mesh and the r8000 there is some delay in picking up devices etc, but nothing concerning as of now.
      ty
