Max13
Dec 16, 2019Tutor
Adding more than 1 extender (EX7700) stops Wifi connecting to Internet
I have a Nighthawk R7000 Router and 3 EX7700 Extenders. For several months I have had this set up working, with all 3 extenders connected via Ethernet in different rooms. With that set up all 3 Exten...
Dec 16, 2019Guru - Experienced User
If the extenders are far enough away from each other that they can't pick each others signal up, it works fine. its when there's a strong enough overlap and they start connecting to each other that you get issues. Maybe something changed in your environment or a firmware update optimized the power/wireless setup enough to cause them to pick each other up.
Max13
Dec 24, 2019Tutor
I ended up just resorting to having 1 extender on the same SSID and the others on different ones. That works fine with only downside being it's not truly seemless when using mobile devices around the house. Anything fixed I've connect to whichever SSID is closest. A bit annoying that I used to have a seemless single SSID across 3 extenders but not a terrible compromise and I just couldn't face messing around trying to get it to work anymore!
- plemansDec 24, 2019Guru - Experienced UserWhen you're needing to run that many extenders, its a great idea to upgrade to a mesh network that is designed to run with that setup. the "mesh" extenders are a hybrid and basically designed for just a router and single extender. Past that, the route you're currently using is advised or upgrading.
