Ordnances
May 25, 2021Follower
Adding MS80 to 3-pack AX3600
Hello everyone, I am buying the Tri-band AX3600 3-Pack (MK83) to extend my home wifi, can this 3-pack be added with additional 2 Sattelite MS80 to the kit to make it work? Thanks in advance!...
May 25, 2021Guru - Experienced User
I know you can add satellites but i'm not sure about the max satellites it'll support with the MK system.
With the orbi system, you see performance degredation after 6.
How many satellites can you add to an Orbi WiFi System? | Answer | NETGEAR Support
Maybe Christian_R has more info.
