MSBayou's avatar
MSBayou
Adding second EX8000 extender
I am adding a second EX8000 range extender to my network to further extend my WiFi coverage. How do I pair it to my existing network and can it use the same SSID?
  • Hi MSBayou,
    Welcome to the community!
    Yes, you can take advantage of the One WiFi name feature of the EX8000 and even have it daisy chained to to the existing EX8000 if it will be placed in a location where it can only detect the extended signal. The process is similar to how you initially setup the existing EX8000.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi MSBayou,
    Dexter
    Community Team
    • TaylorSFGuy's avatar
      TaylorSFGuy
      Should I power down the first extender during setup of #2 so I know the second extender is connecting to the router directly?
      Additional question - In the overlap signal areas I'm experiencing wifi devices hanging on to the weaker connection instead of moving to the stronger source.  Is there a way to set a "drop" condition?  Most of the devices I intend to attach to the extender will not be moving (cameras) but when I'm moving through the house with my phone I'm noticing this situation.  Thanks for your help.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi TaylorSFGuy,
        I assume you have One WiFi Name enabled. Yes, turning off the first extender is a good way to do it. Just make sure that the main router's signal still reaches the location of the second extender.
        When you say "weaker connection", are you referring to the 2.4Ghz band? How are you testing this? Does this issue persist on all 5GHz capable devices?
        Dexter
        Community Team
