Blaze2025
Jan 11, 2025Guide
Adding wired wifi extender to my rax41 router
Hello all. I am simply looking for something. I have the rax41 nighthawk router in my basement. I want to run ethernet from that router to a wifi extender out to my garage. Can someone recommend a pr...
Jan 12, 2025Guru - Experienced User
Many of netgears extenders have ethernet ports and support access point mode.
You can go here: https://www.netgear.com/home/wifi/range-extenders/
and then filter it by the specs you want
Blaze2025
Jan 12, 2025Guide
I appreciate this. I am aware that they have eithernet ports. But to me it seems like most of them are to hook up devices. I see alot of wifi extenders wirelessly from router and then the extenders only having eithernet options to hook up devices. I don't understand support access point mode. I want something great that can support my 1gb download speed that can connect from my already existing netgear router. And use the extender for wifi wireless broadcast only. Your message was pretty general, ill try and follow but looking for more clarity on extender type and direction on accomplishing what i am trying to do please
