PeterBarber
Aug 30, 2020Aspirant
After a power outage, i can't reconnect Nighthawk x6s to router
After a brief power outage, I'm unable to reconnect to my router. I have tried both the WPS buttons and using the Nighthawk app. When I try to select nighthawk in my connections, it either says can't ...
Aug 30, 2020Guru - Experienced User
have you tried hardwiring into it and using the installation assistant?
If you do, shut off the wifi on the device you hardwire in so it doesn't default back to wireless.
Also, try the factory reset again. Push and hold reset for 7-15 seconds while powered on.
If it doesn't work, where does it fail?
What are the leds on it doing?
CBmike
Netgear Base Station mac Number B03956F6FF23 . I can not get my base station to be recognized on my computor anymore..
I am trying to do a reinstall but Netgear is telling me that I have an incorrect model number.
This is an older system when it ewas Arlo/Netgear and it always worked fine. My wife has her arlo system and it is wroking great.
I am not very computor savey which does not help.
Any and all info will be apprecated..
- plemansAug 31, 2020Guru - Experienced User
CBmike wrote:Netgear Base Station mac Number B03956F6FF23 . I can not get my base station to be recognized on my computor anymore..
What I'd recommend is starting your own thread.
Include proper model numbers for your devices, what you've tried, what errors your getting, and maybe then we can help fix it for you.
