Enex
Dec 05, 2024Aspirant
After few minutes all devices get disconnected from extender Ac1200
It's been a month since I switched my provider, had no issues before. Now I have continuous disconnections fro the repeater. I'll try to list all the tests I've already done. -Factory reset both rout...
Dec 05, 2024Guru - Experienced User
1. What router do you have?
2. what extender do you have (AC1200 is a speed)
3. what firmware is on the extender?
Enex
Dec 06, 2024Aspirant
It already has the latest firmware and still doing the same thing, I tried then the fastlane technology both ways and still doesn't seem to fix anything.. I tried to use an app called (wifiman) to scan the area. I have lots of WiFis interfering so I tried to move channels but even if I put it manually, it seems to go back to auto and connect to che full channels.. I will try it now as an acces point hoping it works and if not I'll make a Lan connection through the house ...
- plemansDec 08, 2024Guru - Experienced User
And we still don't have any more info.
the "model" extender you posted is a speed, not a model.
and we don't know your router that you have. Thats key too.
Or the firmware you're on. I've long ago quit trusting people when they say "its the latest" and then later, we find out it isn't.
