kolczdm1
Jan 26, 2021Aspirant
After Install of EX7500 I do not have the 2.5 or 5.0 Networks in my listing?
After installing the EX7500 by following the instructions that came with the device I do not have the new networks 2.4 or 5.0 in my network listings. All the lights are on the extender. If i try to g...
Jan 26, 2021Guru - Experienced User
If you log into the comcast router, does the extender show in its connected devices page?
Did you setup the EX7500 using wps? If so, it sets up using mesh mode by default. Meaning it has the same ssid as the router.
kolczdm1
Is it possible to turn off the mesh setting when in setup? Will it create the 2 networks?
- plemansJan 26, 2021Guru - Experienced User
Yes you can disable that. Its under Onewifi in the extenders settings
- kolczdm1Jan 26, 2021Aspirant
Thanks for the info. Now my 2 networks show and i can connect but im getting a "Weak Security" Message for both. My original Network does not show this error. What do i need to do to get a stronger security? I tried to change it to a WPA3 as it says in the instructions but I do not have that selection. My X1 Xfinity router is only 2 weeks old. I it a setting within the extender settings?
Thanks for any assistence.
WPA3 is a hardware change. The AC versions don't have it.
the notice is a recent implementation of notifying people of weaker security but for the most part, wpa2 is still in use by the majority
