sojourn_out
Aug 18, 2020Aspirant
Airbnb Wifi Extender Options (6,800 sq ft.)
Hello! I am a property manager for a 6,800 sq. ft. Airbnb property. I have been working with different wifi pods/extenders to help increase connectivity and speed for my guests. These have not ...
Aug 19, 2020Guru - Experienced User
options that are compatible?
RBS20
RBW30
RBS40
RBS40V (with voice)
RBS50
RBS50Y (outdoor)
All of them would work.
Something to keep in mind though is the 50 series has a 1733mbps backhaul. The lower series (40 and under) use a slower 866mbps backhaul. So if you buy and use those and are daisy chaining, make sure they're at the end of the chain so they don't create a bottleneck.
what I mean is go:
rbr50----->rbs50------>rbs/rbs40 and under
dont' go:
rbr50---->rbs20------>rbs50
The versions with the 866mbps backhaul still work great but its just something to keep in mind if you're daisy chaining satellites.
And thats if you have the RBK53 kit. I was assuming that because you had it in the signature/device line.
- sojourn_outAug 21, 2020AspirantHello! We currently have one RBK23 router and two RBS20 satellites.
These have worked for a while, but we would still get dead spots around the property.
In this image it shows the property. We have 8 units total. I have the router (red spot) in Unit 1, and satellites (also red spots) in Unit 5&8.- plemansAug 21, 2020Guru - Experienced User
You can continue to add satellites. I've read of people having up to 8 units but netgear doesn't recommend that much. As well as they only recommend daisy chaining up to 2 units. Again, you can do more but you might take a performance hit.
I personally have ran a router + 4 satellites without issues
- sojourn_outAug 24, 2020Aspirant
Thanks for the great advice.
What if I were to extend my reach to not the RBS20 satellites, but the Orbi Voice?
Would I see a more dramatic change in speed and connection?
Say if I was to buy 5 of them to complete the entirety of the property?
