andreah1
Feb 07, 2022Apprentice
All LED lights blinking intermittent and not able to log in
I received the EX3700 yesterday in hopes of extending my signal a little further for a camera to pick up. Live in a small home - 1500 sq. ft. ranch. Router is on one side of the house and want to p...
Feb 07, 2022Guru - Experienced User
the routerlogin address if for a router.
the extender uses mywifiext . net or its ip address.
Did you try those?
you can try factory resetting the extender and reinstalling it.
Use the installation assistant. And move it away from the router in steps. It could be getting interference/obstruction issues.
- andreah1Feb 07, 2022Apprentice
Sorry, should have clarified, I used both addresses, the mywifi when trying to set up the extender and the routerlogin when I was trying to see if something was wrong with my router. Neither would work, the mywifi worked once randomly, long enough that I thought I set up the extender but now not sure all all the lights keep going thru this routine and don't stop.
What installation assistant? I didn't have anything like that pop up - I refreshed over and over when trying to set up the extender and as I said it randomly popped up finally...there was no assistant, I just clicked on set up new extender, had to check both 2.4 and 5 and put in the password I wanted. How do I find the installation assistant? That would probably help! I will reset tonight and try again and also try your hint of moving slowly towards where I want it to go. Have an open concept house so not sure what could be disturbing it, the router and extender can just about "see" each other. :)
- plemansFeb 07, 2022Guru - Experienced User
here's a video walk through.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
Thank you, just viewed, it's exactly what I did last night. The first few times I wasn't sure I was supposed to keep my regular connection there or not but I clicked on the extender, "connected" then tried to go to mywifi, as I said, it didn't work most times but finally did. So, maybe all is good and I'll just reset and do it again tonight and slowly move it to where I want it. Still baffled as to why I can't log in to routerlogin.
