andreah1
Feb 07, 2022Apprentice
All LED lights blinking intermittent and not able to log in
I received the EX3700 yesterday in hopes of extending my signal a little further for a camera to pick up. Live in a small home - 1500 sq. ft. ranch. Router is on one side of the house and want to p...
andreah1
Sorry, should have clarified, I used both addresses, the mywifi when trying to set up the extender and the routerlogin when I was trying to see if something was wrong with my router. Neither would work, the mywifi worked once randomly, long enough that I thought I set up the extender but now not sure all all the lights keep going thru this routine and don't stop.
What installation assistant? I didn't have anything like that pop up - I refreshed over and over when trying to set up the extender and as I said it randomly popped up finally...there was no assistant, I just clicked on set up new extender, had to check both 2.4 and 5 and put in the password I wanted. How do I find the installation assistant? That would probably help! I will reset tonight and try again and also try your hint of moving slowly towards where I want it to go. Have an open concept house so not sure what could be disturbing it, the router and extender can just about "see" each other. :)
Feb 07, 2022Guru - Experienced User
here's a video walk through.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
- andreah1Feb 07, 2022Apprentice
Thank you, just viewed, it's exactly what I did last night. The first few times I wasn't sure I was supposed to keep my regular connection there or not but I clicked on the extender, "connected" then tried to go to mywifi, as I said, it didn't work most times but finally did. So, maybe all is good and I'll just reset and do it again tonight and slowly move it to where I want it. Still baffled as to why I can't log in to routerlogin.
