PatriotMary
Dec 02, 2020Aspirant
Alternate login for Netgear WN3000RP
I have an older range extender that I'm still trying to use. I have not been able to log onto the device with therecommended address (forum rules won't let me post it) to see if the firmware needs t...
Dec 03, 2020Guru - Experienced User
I'm not sure what speeds you were getting before but 20mbps off the wn3000rp isn't aweful. its actually pretty accurate. N300 extenders are slow from the start. 2.4ghz is a slow band. And extenders by their very nature drop throughput 50% because they have to send router----extender and then extender----device and they can't do both at once.
If you read through N300 extender reviews, the 20-25mbps is about what you expect from them.
I'm betting your speeds off the linksys and the hotspot are from the 5ghz. 5ghz is much much faster but it doesn't broadcast as far or though as much materials.
PatriotMary
Dec 05, 2020Aspirant
So, just as a follow up: I finally was able to login to my WN3000RP Extender, and I got the firmware updated. I was able to get acceptable service to my shop, which was my main concern.
On Friday, my new Range Extender (AC1900 EX6400) arrived. I dropped everything to get it installed. It was a little finicky, but I finally got it set up and running. In my shop, I am getting a 37 ping, 104.34 mbs download and 33.24 upload. I'm pretty happy with those numbers, and will keep the new extender (if the numbers were comparable, I thought I might return it).
My next disaster comes when I get my new Cyber Monday laptop gift to myself, and I get to go through all of that BS. It just never fails that software/hardware problems occur at my shop's busiest time of the year.
Thanks again, for your help.
