beezer
Sep 12, 2017Apprentice
AmA Handoff
Moving to a new office. I will have several Cat7 drops. The R6300v2 and R7800 listed in this post are the current routers (used as WAPs only) in my old office. Now... I'd like to wire the WAPs an...
- Sep 15, 2017
Hello Beezer
Yes the ex8000 can do it and you may want to look at our business Access points.
DarrenM
beezer
Adendum: Before I get this response in this forum too, I DID consider ORBI. The (confused) consensus is that wired backhaul is a work-in-progress, plus, I really don't feel the mesh mania. When someone in authority says wired backhaul works, I might use it in places just for esthetic reasons. Still, it feels like joining a cult and giving up fine control, just to get hand-off.
- DarrenMSep 15, 2017Sr. NETGEAR Moderator
Hello Beezer
DarrenM
- beezerSep 15, 2017Apprentice
Thanks. I should mention this is a home office, but... suggest a business WAP for me, please?
Actually, as long as I'm asking for free pre-sales advice / consulting... :smileywink:
I have a Linksys LRT224 (apostasy!). If I buy two WAC730s will I be able to:
1) Tune the power levels on the WAPs so they can be as close as 50 feet apart?
2) Set up a guest profile with a tagged VLAN for all bands (e.g., untag the non-guest LAN securely)?
3) Have the guest profile serve DHCP/DNS from the LRT224?
Bonus: Is there a better SOHO switch/firewall from Netgear, and what makes it good?
