Tito1987
Aug 27, 2020Follower
An extender with a strong range
Hello, I need help: which is the ideal product to overcome three concrete walls? Thank you in advance.
1 Reply
to overcome 3x concrete walls? A masonary drill bit and an ethernet wire.
concrete is literally one of the materials that is the best at blocking wifi. If you did get a signal through it, good luck getting much for bandwidth.
