GilDawson's avatar
Aug 17, 2022
Another device on the network is using your computer's IP address; EX6100v2 culprit
We have a Netgear EX6100v2 Range Extender working with an Arris NVG443B  DSL modem/router.   About 15 devices connect via WiFi; no cables.   I configured the EX6100v2 to use one SSID throughout.    ...
  • plemans's avatar
    Aug 17, 2022
    You can set devices with reserved or static ip addresses so that doesn't happen.
    Did you setup the extender using wps or using the installation assistant?
