GilDawson
Aug 17, 2022Tutor
Another device on the network is using your computer's IP address; EX6100v2 culprit
We have a Netgear EX6100v2 Range Extender working with an Arris NVG443B DSL modem/router. About 15 devices connect via WiFi; no cables. I configured the EX6100v2 to use one SSID throughout. ...
- Aug 17, 2022
You can set devices with reserved or static ip addresses so that doesn't happen.
Did you setup the extender using wps or using the installation assistant?
Aug 17, 2022Guru - Experienced User
GilDawson
Aug 17, 2022Tutor
Thanks, plemans, for your quick response.
I did set up the EX6100v2 using the assistant.
Setting up with reserved or static IPs seems like a reasonable solution. I had not thought of that.
I suppose I should set up both the Arris cable modem/router and the EX6100v2 with the same reserved IP for each device, n'est pas?
I'll have to learn how to do that.
Thanks for the suggestion.
--Gil
