lasttombstone
Jun 02, 2020Aspirant
Another security key plea
Please be patient with an old guy who doesn't know much. Bottom line is I can't connect to the extender network. I keep getting the 'security key" thing. None of the numbers on the back of the uni...
Jun 02, 2020Guru - Experienced User
Have you tried hardwiring into the extender for setup? If you hardwire in a laptop/desktop to it, make sure to disable the wireless on the device you connect with so the device doesn't default back to the wireless
lasttombstone
I have not but will try.
- lasttombstoneJun 02, 2020Aspirant
With the extender plugged into he outlet, the cable goes from the router to the modum? Then what?
- plemansJun 02, 2020Guru - Experienced User
connect your pc/laptop directly to the extender via ethernet cable.
Disable wireless on the device you're connecting to the extender so you can ensure the pc/laptop isn't defaulting back to wireless during setup.
OK.... extender is connected to the PC by an ethernet cable. Wireless is turned off to the PC
