bigim
Jan 06, 2020Aspirant
Antenna locations
Good afternoon Does anyone know what antenna does what? :- which one of the antennas receive the info from the router Ian
Jan 06, 2020Guru - Experienced User
I guess i'm a bit curious about this question.
The EX7000 is a 3x3:3 antenna for both 2.4ghz and 5ghz. I didn't see any internal antennas for the EX7000 on the FCC documents which means that each antenna has a 2.4ghz and 5ghz antenna in it. It also shows that each radio has a rp-sma connector which also implies thats the external antenna.
Each one can receive and transmit.
What's your goal here or why are you wondering this?
bigim
Apr 14, 2020Aspirant
sorry its been a while , what im after is to know what antenna does what ie:- does the top one tx/rx from the router , then the others are the repeat antenna/s?
