Firespooks
May 14, 2020Follower
Antenna positioning
I just installed my range Extender. . What is the best position for the 2 antennas ? The unit is plugged in sideways into the outlet.
1 Reply
Best position? The one that works properly.
https://lifehacker.com/the-best-way-to-point-your-wi-fi-router-antennas-perpe-1605924745
You can try speedtesting and moving the antenna's around to see what works best.
