lboz1009's avatar
lboz1009
Follower
Apr 20, 2022
Antenna Replacements for EX7000 WiFi Mesh Range Extender?
Where can I get new connecting antenna's (3) for the EX7000 WiFi Mesh Range Extender with AC1900 Dual Band Wireless Signal Booster & Repeater plus Mesh Smart Roaming?  I was using it as a mesh extender for my EX7000 Modem/Router and my cat chewed the antenna's (new location will be found!). After a year of no problem, all of a sudden it wasn't receiving/sending and I noticed the lights went off and I noticed the damage. I just need to replace them, but don't see unit specific replacements available. TIA for any help/suggestions!
  • Look like like pretty standard dual band rp-sma antennas. They can be found all over amazon for pretty cheap.
1 Reply
  • plemans's avatar
