Harry63
Mar 06, 2020Aspirant
Arlo basestation disables 2.4ghz band on ex8000 as access point
Somewhat weird but worth mentioning. On 2 different routers the Arlo basestation 4500 did not function when then 2.4ghz was disabled on the routers. When connected on my netgear ex8000 (as accesspoin...
DexterJB
Mar 11, 2020NETGEAR Moderator
Hi Harry63, what is the firmware version of the EX8000? Does the issue persist if you have the base station wired to the main router? Also, have you tried setting up the EX8000 in extender mode?
Dexter
Harry63
Mar 12, 2020Aspirant
Hello Dexter,
Here are my specifications:
Router EX8000, Firmwareversion: V1.0.1.206
Arlo Basestaion VMB4500r2, firmware 1.15.01_3092_d878851
I have not tested in Extender mode, this is not an issue for me.
Harry
- DexterJBMar 23, 2020NETGEAR Moderator
Hi Harry, the EX8000 is an extender and not a router.
NETGEAR Team
- Harry63Mar 24, 2020AspirantThe ex8000 is setup as an access-point. I now have two ex8000 as access points. All works fine but on both the basestaiton disables the 2.4ghz band
- DexterJBMar 30, 2020NETGEAR Moderator
Hi Harry, that is quite unusual, does the issue persist if you have the base stations wired to the main router?
Dexter
