CarlM40484
Apr 22, 2013Novice
Assign Device Name to MAC address
I have different access points and have noticed that many times there is no Device Name associated with a MAC address. I want to know if there is a way to globally assign a device Name to a MAC addre...
CarlM40484
Apr 23, 2013Novice
jmizoguchi wrote: You can not. router uses ARP to get the device name.
Some device (not computer) may not have a device name that will not show as well
Can the APR not have a flag set to display a specific name to a specific MAC? I thought that ARP used some of the router memory to make the resolution faster.
One problem is that sometimes the name appears and other times it does not. I have even had a reported wireless connection without an IP address. This happens even after rebooting (thru Genie).
Sure would like to change this so the name appears.
Thanks
