justav6
Jul 14, 2012Aspirant
Attempting to set static address on WNR2000v3
My WNR2000v3 router and Samsung Blu Ray player will not communicate to do an auto setup, but if I do a manual setup on the Blu Ray player, the router picks it up and everything works, so I am trying t...
Jack_
Jul 15, 2012Aspirant
What manual IP setting did you use on the Blue Ray player?
What exact DHCP range was set in your WNR2000v3?
Of course, you cannot set an IP address reservation outside the DHCP range!!!!
Setting up your Blue Ray player manually with a static IP address outside the DHCP range of the WNR2000v3 is all you have to do in order to make this work....
