justav6
Jul 14, 2012Aspirant
Attempting to set static address on WNR2000v3
My WNR2000v3 router and Samsung Blu Ray player will not communicate to do an auto setup, but if I do a manual setup on the Blu Ray player, the router picks it up and everything works, so I am trying t...
jmizoguchi
Jul 15, 2012Virtuoso
justav6 wrote:
I did go in and limit the range on the router and I am using an address that is 10 higher than the range.
How can it be invalid if it works?
When you use Address reservation under lan setup, make sure to use WITHIN the DHCP range.
Terminology Static address is define to used on device such as pc, media devices, and other devices then router in general in your case.
