justav6
Jul 14, 2012Aspirant
Attempting to set static address on WNR2000v3
My WNR2000v3 router and Samsung Blu Ray player will not communicate to do an auto setup, but if I do a manual setup on the Blu Ray player, the router picks it up and everything works, so I am trying t...
jmizoguchi
Jul 16, 2012Virtuoso
I had tried to assign a static address before I had limited the range and had gotten the same message. I am trying to input all the same data into the the static address that is in the Blu Ray that seems to be working and it continuously says that it is an invalid ip address.
using address reservation under LAN required to use WITHIN DHCP .
using static IP on player required to use OUTSIDE DHCP
