Jwoulfe
Oct 08, 2021Tutor
AX 1800 (EAX20) Extender log in connecting to the internet source router not the Mesh Extender
My AX1800 Mesh Extender (EAX20) log in process has recently been unable to connect either by the web or Nighthawk app. When trying to log into the extender with routerlogin.net, its trying to log int...
Oct 08, 2021Guru - Experienced User
to log into the extender, either use its ip address or use mywifiext . net
If you log into the router, you should be able to get the IP address for the extender.
Jwoulfe
Oct 08, 2021Tutor
Very good! That works fine. I guess the true issue must be the Nighthawk App. Not sure if this is the proper place for discussion but it seems the App, originally connects to the EAX20 extender and runs fine. Then after a while it switches to the internet source router and gets stuck there. I cannot get back to the EAX20.
