s400
Oct 16, 2024Aspirant
AX1600 EAX12 stopped working - how do I fix this ?
All of a sudden this evening, one of my AX1600 EAX12 extenders stopped working. I have two (for front and rear of building) and I use them primarily to hook up LAN cable connected devices (which don...
Oct 16, 2024Guru - Experienced User
did you set it up using wps or using the installation assistant?
have you tried factory resetting and using the assistant? (don't use wps)
