bazme82
Oct 31, 2023Follower
AX1750 wifi extender just not working
Every time i try resetting it theres a new issue, but the one I’ve had consistently has been with it giving a good connection with google’s speed test, but can’t actually give me any internet on anything else, like the ookla speed test. It won’t let me run a speed test through the nighthawk app either. I’ve tried moving it around the house but won’t even work when its in the same room as the router. Ethernet on it also gives a good google speed test but can’t even load the ookla speed test and barely gives a connection to stuff like discord. I’m really at a loss for what to do here, could y’all help me?
1 Reply
What actual model do you have? AC1750 is a speed
what firmware is on it?
What router is it connected to?
What method of setup did you use?
