David-H
Sep 16, 2020Tutor
AX1800 - 2.4 Ghz and smart devices not connecting
Not able to connect my Smart Bulbs and other devices to the 2.4 Ghz. The SSID shows up but there's only one SSID for both the 2G and 5G networks. Then my smart devices app can't connect to the networ...
David-H
Sep 17, 2020Tutor
Thanks. However, the mesh system doesn't have the "Smart Connect" feature. I'm not able to do what you're saying.
David-H
Sep 17, 2020Tutor
PROBLEM SOLVED!!!
In order to connect my smart devices my phone has to be on the 2.4Ghz network.
Step 1: unplug the 2 satellites to minimize the 5G range.
Step 2: set smart device into pairing mode
Step 3: walk to my backyard in order to get out of 5G range and only 2G range
Step 4: CONNECTED!!! Set up smart device
Step 5: Repeat as necessary for additional smart devices
- plemansSep 17, 2020Guru - Experienced User
Sorry, would have went over that method but you didn't have a model.
glad you got it fixed!
