DwobDwob
Jun 01, 2024Initiate
AX1800 4-Stream WiFi 6 Mesh Extender suddenly stopped working
After working perfectly for a few months the Router symbol’s light continuously swapped between red and green and it stopped working. I’ve tried factory resetting it, I’ve tried just reconnecting it b...
DwobDwob
I replied to this earlier by email and I’m not sure if you replied to it because the email turned into some weird website transcript thingy. So in case you didn’t see I said if I plug the extender into the router then do the generic setup on the Nighthawk app it should work? It was only the router icon alternating between red and green but now it’s completely disconnected and every light is off besides the power light which is orange. And yes I have reset it.
Jun 03, 2024Guru - Experienced User
If the power light is orange, it tends to indicate a corrupt/bad boot process.
You can try recovering it with tftp or nmrpflash.
Are you on Windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walkthrough using a TFTP client. Use the built-in one for Windows 10, though. The video is more of an example of how it's done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Here's a video of nmrpflash: https://www.youtube.com/watch?v=qxQu3wtpFYo/amber
