PatGainer
Dec 05, 2023Aspirant
AX1800 4-stream WiFi Mesh Extender
I also just purchased a AX1800 4-Stream WiFi mesh extender. Having a difficult time getting it to connect. Used WPS several times and it seems to connect but the router link LED never comes on. I am ...
PatGainer
I also just purchased a AX1800 4-Stream WiFi mesh extender. Having a difficult time getting it to connect. Used WPS several times and it seems to connect but the router link LED never comes on. I am left with the Power LED of course, the client LED and the WPS LED. All three green with the client blinking.
I believe it is working but isn't the router LED light also suppose to be on? It is only 20 feet from my router so it should have a solid signal.
Thoughts?
- plemansDec 08, 2023Guru - Experienced User
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
