ghostface2007
Mar 21, 2021Tutor
AX1800 EAX20 Extender Suddenly Not Routing or Going out to Internet
Hello, I have used the Nighthawk EAX20 for about a year now. As of yesterday, my extender seems to have stopped routing traffic. My router and all other devices are fine, as is the wireless signa...
- Mar 22, 2021
The G3100 is verizon's version of mesh.
have you went into the router and disabled self organizing network?
Go to wireless settings--->advanced security settings---->other advanced wireless options--->self organizing network.
set it to off and try.
Mar 21, 2021Guru - Experienced User
What router do you have it connected to?
are you installing it using wps or using the installation wizard?
ghostface2007
Mar 21, 2021Tutor
I am connecting the extender to a Verizon G3100 router. Until yesterday everything was working fine. As I said, I made no known changes to the network. I tried reverting the firmware on the extender and nothing. I am using the Netgear wizard through the extender configuration page on my browser. It detects the 5g and 2.4g networks and connects, setup successfully completed, but still provides no internet connection. I have noticed that after I setup the extender, after two minutes or so the configuration page becomes unavilable, with a timed out connection.
Appreciate any tips.
- plemansMar 22, 2021Guru - Experienced User
- ghostface2007Mar 22, 2021Tutor
Thank you that seems to have done it! I appreciate the help.
Glad it worked!
