mikecextender
Apr 05, 2024Follower
Ax1800 extender wont connect
I have this extender and it has worked fine. i tried to change the name and it stopped working. Now i can't get it to reconnect. main router is RS400. 1. i tried to just re connect and nothing 2. i...
Apr 05, 2024Guru - Experienced User
Have you tried scortched earth and factory reset both router and the extender?
Push and hold reset for 7-15 seconds and then reinstall them both?
