Roby6266
May 16, 2021Aspirant
AX1800 Firmware upgrade
Hi, I am a bit confused about the firmware upgrade of my device. For the APP the firmware is ok and the versione is 1.0.0.52. Instead if I use the web interface from a PC, the system indicates a ne...
May 16, 2021Guru - Experienced User
You have the MK system?
If so , the latest firmware is even newer.
try a manual firmware upgrade process.
https://www.netgear.com/support/product/mk62.aspx
