Temwyatt
Nov 18, 2022Follower
AX1800 wifi extender
I need to extend my wifi coverage to my barn from my house. I have a good signal outside the metal barn. Because of the metal, there is no signal in the barn. Can I connect an external antenna to ...
- Nov 19, 2022
Here's the questions. If you stick the antenna on the outside of the barn, what broadcasts inside it?
Usually what I recommend is something like a point to point (like netgears airbridge) system that lets you connect the 2 (house/barn) and then connect an access point inside the barn. That way you have a good connection between the 2 and something broadcasting inside the barn.
Nov 19, 2022Guru - Experienced User
