britman98
Jan 24, 2023Guide
AX1800 wifi mesh extender ethernet ports
Just purchased the AX1800 (EA20) which I have setup and appears to be working fine! My issue is the ethernet ports don't appear to be working, is there a setting I need to check? I have set up this ...
Jan 24, 2023Guru - Experienced User
What router did you connect it to?
Did you set it up using wps, the installation assistant, or using the app?
What firmware is on it?
Have you tried other devices?
britman98
Jan 24, 2023Guide
Router is: Netgear Nighthawk R6900P
as previously mentioned I set it up with the Nighthawk app.
The firmware updated as soon as it was setup.
