britman98
Jan 24, 2023Guide
AX1800 wifi mesh extender ethernet ports
Just purchased the AX1800 (EA20) which I have setup and appears to be working fine! My issue is the ethernet ports don't appear to be working, is there a setting I need to check? I have set up this ...
CrimpOn
Jan 25, 2023Guru - Experienced User
WiFi extenders with Ethernet ports typically "just work". (i.e. no setting or setup required). How have you determined that these ports are not working? (what was connected? Symptoms? - error message? what?)
britman98
Jan 25, 2023Guide
I have tried a couple of devices including my laptop, its like the ports are there but they are not hooked up, just dead! No error messages, nothing!
I am thinking about returning it and getting my money back. Thanks for your help.
- CrimpOnJan 25, 2023Guru - Experienced User
I agree. It is defective.
