britman98
Jan 24, 2023Guide
AX1800 wifi mesh extender ethernet ports
Just purchased the AX1800 (EA20) which I have setup and appears to be working fine! My issue is the ethernet ports don't appear to be working, is there a setting I need to check? I have set up this ...
Jan 25, 2023Guru - Experienced User
Have you tried setting it up using the installation assistant and not the app or wps?
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
britman98
Jan 25, 2023Guide
I finally figured it out, turned off “smart connect”. Went through setup again and they were working!
Thanks again!
Thanks again!
