Popo55
Jun 24, 2026Aspirant
AX2400 Extender
I am having issues, worked fine 1st week, now not so, in and out, indicator lights on and off. Did a factory reset, seemed to work....for a while. Any advice?
1 Reply
- what actual model do you have? AX2400 is a speed
- What router is it connected to? (model)
- What method of setup did you use? WPS push button, the app, the installation assistant?
- What issue are you having? Saying not so much, in and out, doesn't tell us much? When it goes out, does the SSID stop broadcasting, are devices connected but don't work, what actually happens in detail
