JKW787's avatar
JKW787
AX6000 AX 8 Mesh extender
Hi I have the above on the 2nd floor of my building connected to a Fritzbox 7530 on the 1st floor by ethernet cable. We are unable to connect to my Chromecast and SONOS. A bit of research  suggested...
  • plemans's avatar
    Sep 09, 2022
    Sonos devices have issues on mesh systems. Do a search on their forums and you'll find a ton of posts about it.
    Make sure that if you have a bridge, its only connected to the router and not the extender.
    Something else you can try is setting static ip addresses on your devices.
