JKW787
Sep 08, 2022Aspirant
AX6000 AX 8 Mesh extender
Hi I have the above on the 2nd floor of my building connected to a Fritzbox 7530 on the 1st floor by ethernet cable. We are unable to connect to my Chromecast and SONOS. A bit of research suggested...
- Sep 09, 2022
Sonos devices have issues on mesh systems. Do a search on their forums and you'll find a ton of posts about it.
Make sure that if you have a bridge, its only connected to the router and not the extender.
Something else you can try is setting static ip addresses on your devices.
JKW787
Sep 09, 2022Aspirant
Yes that's what I have.
Another frustrating hour with Netgear support last night.
In the end gave up with them.
Some of the complication was having a guest network which is used for the SONOS and Chromecast, but not to communicate with the router. This was a problem in trying to use the app. Cracked it in the end though. Now set up in mesh mode again. Still have issue with extender using different IP addresses. This necessitates turning phone wifi off and on again to control SONOS and Chromecast. Am I going to be able to do anything about this? I know I can fix the IP address on the router, can I do that on the extender? Do I want to , it will compromise my security?
Thanks for your input so far.
JKW
Sep 09, 2022Guru - Experienced User
- JKW787Sep 09, 2022Aspirant
Thanks for that.
Ill research SONOS and static IP addresses.
