umt001
Jun 14, 2021Follower
AX6000 WiFi Range Extender -EAX80
Do the AX6000 WiFi Range Extender -EAX80 has the option to turn the power *OFF* automatically and power *ON* for a period of time (when not using to save power) ? Thanks
Jun 14, 2021Guru - Experienced User
Not that I know of.
But you could do it with a simple smart switch (which would still use power)
