zorrowpg
Aug 19, 2023Aspirant
AX8 AX6000
After completing the installation of the Eax80 WI-FI extender I notice when I go into the Nighthawk App and under devices it shows a 2.4GHZ and 5GHZ. Under the 2.4GHZ are my two AT&T cell phones. Un...
michaelkenward
Aug 19, 2023Guru - Experienced User
zorrowpg wrote:
Under the 2.4GHZ are my two AT&T cell phones. Under the 5GHZ I see computer and smart TV’s.
It is up to the wifi clients your anonymous cell phones to connect to the wifi connection that suits them best.
The router has no control over that.
As the EAX80 is an extender, you might like to look at the router it talks to. That controls your network.,
Do you have Smart Connect enabled?
- zorrowpgAug 19, 2023Aspirant
Smart Connect on the Router or EAX80 extender??
- michaelkenwardAug 20, 2023Guru - Experienced User
Extender. You haven't said what the router is, so we don't know if it supports that feature.
- zorrowpgAug 20, 2023Aspirant
My router is for AT&T fiber... BGW320-505
