bkrett
Oct 16, 2016Aspirant
Best device(s) to get wired signal to barn?
I am trying to figure out if there is a configuration of devices that will get me a connected ethernet port in my barn. I have an R6300 Wireless router and was able to get decent wifi signal out to t...
DarrenM
Oct 18, 2016Sr. NETGEAR Moderator
Hello bkrett
A lot of our extenders have Ethernet connections on them which should work but I would check what type of speed you need to keep your security system running because when you use a extender you are going to lose some of your internet speed.
DarrenM
- bkrettOct 18, 2016Aspirant
HI, Thanks for the input. The wifi extender I am using isn't actually located out in the barn where I need the ethernet connection. I tried it out there but wasn't close enough to my router for a strong signal. I currently have it plugged in at the end of the house closest to the bard which seems to be working to pick up a nice strong signal and also give me a good wifi signal out in the barn. I read that you can't really piggy-back extenders off of each other, so I am looking for some sort of adaptor that picks up a wifi signal, but has an ethernet port. Thanks.
- DarrenMOct 18, 2016Sr. NETGEAR Moderator
Hello bkrett
Have you looked at orbi it has Ethernet and you do not lose the wifi signal like you do with using extenders.
DarrenM
