FernandoF
Sep 09, 2015Follower
Best extender/repeater for NETGEAR AC1750 Wi-Fi DOCSIS 3.0 Cable Modem Router (C6300)
We recently purchased a NETGEAR AC1750 Wi-Fi DOCSIS 3.0 Cable Modem Router (C6300), we set up our PC in the garage, we have good signal on the west side of the home but are looking for an extender or repeater that will boost our signal to the other side of the home.
Which models are compatible and recommended for this use?
1 Reply
- Babylon5NETGEAR Employee Retired
I have been using an EX7000 for quite a long time without issues, though I run it as an Access Point. If you are able to run a cable to an area close to where you want extra WiFi coverage then I would recommend that kind of AP setup in preference to repeating/extending. I would also suggest that you consider Powerline products e.g. http://www.netgear.co.uk/home/products/networking/powerline/XWNB5201.aspx
