Wally2321
May 18, 2022Tutor
Best Mesh Router for metal barn
I bought a EAX80 but it is not working well with my metal barn. The signal is not getting through. I would like to purchase a Netgear mesh router that can have the router in the barn but I can hook up...
May 18, 2022Guru - Experienced User
If you put an antenna outside the walls, what broadcasts internally to the walls?
And if you buy a router just for this task and another for inside, it'd be better off going with the system designed for point to point as it'll have higher bandwidth and lower latency
Wally2321
May 18, 2022Tutor
Thanks for the reply. I thought you could unscrew the external antenna and attach a cable to an antenna you could put outside the building.
Here is what I read…
https://smallbusiness.chron.com/connect-wireless-router-external-antenna-60161.html
Is this not possible?
